mike-evans
- Sep 16, 2009
- 142
- 0
Thought I would do a bit of maintenance and check float level as per manual. Manual says 5.5-7.5mm, mine was reading 4.2mm, I adjusted it and got 6.1mm, put back together, and now leaks fuel out of overflow pipes? Floats were moving freely when I check before re-fitting bowl...any ideas what it could be? When I was adjusting the float tab to correct the float height, the tab seemed to be quite high and didnt look right, the tab was resting on the needle valve and not compressing it, as the manual says it should.....
