PLEASE SUPPORT DIRTRIDER
Help cover the site's expences for
our 21st year online!
$1, $5, it all helps!
FLUID DRAG...I THINK.
WHEN I HAVE MY CLUTCH PULLED IN AND MY BIKE IN GEAR IT WANTS TO PULL A LITTLE.WHY?? ALSO WHAT SHOULD I BE RUNNING IN MY TRANSMISSION?(OIL)WHAT KIND .
BILL L.
Is your GG fairly new? It needs a little time for break in. Clutch tolerances are tight in the GGs and they use more plates than most bikes. What oil are you running? BelRay Gearsaver will make the GG clutch drag more for some reason. Run Spectro 80W gear oil for best results. If it still drags after break in back bleed the clutch through the slave cylinder fitting. When broken in and set up right, it should start in gear with a good kick.
Glenn
'00 GasGas XC250
- a d v e r t i s e m e n t -
Too much oil (overfilled) may also cause this. Check the oil level with the bleed screw or window if your bike has one.
What fluid are you using in your clutch???
I run Motul 600 brake fluid in clutch & both brakes just like GGNA factory team. It works great.
They also run Spectro 80w 1 qrt.
