Does anyone here make there own cylinder base gaskets? When you start pulling you jug off frequently to check the condition of the top end it can get expensive at $22.00 a pop to replace cylinder gaskets. I was thinking about getting some OEM gasket material and pounding a few out myself. Is anyone doing this? If so. Where are you getting your gasket material from, and how much. Does anyone know how thick the OEM stuff is?
