i called my dealer this morning and he said that OEM gasket (0.020 po) is made for run with race gaz. he said, if i run with pump gaz, you must use a (0.040 po) head gasket.
why? he said, the OEM 0.020 gasket make more compression and with pump gaz, this can make a littles holes on the head piston surface. he call them PING.?
It's true? or i can keep the same OEM thickness 0.020 without prob.
Anybody would say more about that...
My bike kx 250 01 i run 92 pump gaz with maxima S.M :think
