Hi guys,
I looked through past posts and didn't find what I'm looking for even though I'm sure it must have been posted in the past, so if I'm blind and missed the obvious please forgive me. Anyway, I'm a 2-stroke guy and I decided to give a 4-stroker a try and I've got some questions. The bike (CRF 450) is still in the crate. What prep work is necessary? Normally on a two stroke I grease the steering head bearings, linkage bearings and the wheels; I seal the airbox and just give it a once over. Anything else for the 450? Next question: What is the proper break in procedure? Normally on a 2-stroke I put the bike through a couple no load heat cycles, then a couple light rides progressing from only up to half throttle to using full throttle, with a complete cool down between each. Last question: What oils do I use for the engine and tranny for break-in and what oils after break-in? Normally on a 2-stroke (seems to be a recurring theme) I use Castrol GTX 20W-50 and change at least every other ride, for break-in and use thereafter. I'm a fan of the "use the cheaper stuff, but replace it often" theory. What do you think? Thanks for the help. Oh one more question: Mix the gas at 32:1 right? Just kidding. :confused:
