Bike is a 1975 Honda XR75. Carb is spotless, jets are clean. Manual says it needs a 30 pilot and 100 main jet, I have a 30 pilot and 92 main. Manual says needle in 2nd clip from top, I have the clip in the top position. I havent been able to get it to run with the needle in any other position. I just adjusted the valves and visually inspected the points and the meet up flush and square, there wasnt a spec. for the point gap or else i would have measured it. The bike will start up and idle fine (never need to use choke) but as soon as you blip the throttle it will bog. If you rev it to much it will die. Sometimes if you take it real slow you can get the rpms to come up some but not much. Can't figure this one out since it has a fat blue spark and the carb is clean. Any help appreciated. Thanks
