Help Please!! I don't have a manual for my 1980 Husqvarna 250 OR and want to set the timing. Do I back off the piston 2.8mm from top dead center? Whats the best way to do it....put a screwdriver or other pin through the flywheel hole and seat it into the slot in the stator and then move the flywheel with the backing plate loose to 2.8mm back and then take the flywheel off and tighten the backing plate? Is this correct?
