I just cleaned up my KIPS system which was not driving the valves all the way back. Everything is clean and back together thanks to the many great posts here. What I noticed is that the return spring still does not close the valves all the way. I can put a very light torque on the gear nut (left side) and help it get there. I took the govenor shaft gear off to see how much of the shaft travel has spring force in it. It only went a small distance where I could feel the force of the spring and then seemed to go overcenter. Now there is zero spring. It did not sound like the pin sheared. Is it possible to over rotate the shaft/over center from the advance mechanism? Just wondering what I have screwed up. I will be taking it apart tonight. Thanks in advance for any replies. MD
