FYI for those of you contemplating this. I followed FLBusa's procedure (except I have not added the upper clamp shim yet). I have the forks as high in the clamps as they will go w/o hitting the bars. Will test and see if this is the right result and will lower if need be. I have a 2002 KDX 200 and I replaced the entire front end with a 2002 KX 125 front end (using the KDX stem, which a local shop pressed for me for $70 -- an hour of labor). Took a few hours of time tops. Pretty straightforward. Thanks to FLBusa and the others who have posted advice. I have a pic but could not figure out how to post it.
