there is a bolt stripped on my clutch cover, i was searching for an oem replacemaent but it said a had to pay $135 for the whole assy. any slutions on repairing or replacing it
I would suggest looking into a heli-coil. They are fairly cheap and easy to install. Works pretty well for a stipped bolt. It should definately be strong enough for a clutch cover. You can pick one up for the correct sized bolt at just about any auto parts store. Hope this helps.
