I had to rebuild my engine due to a shreaded bearing on the crank. Well I got it back together and it runs but the low end sucks. It seems to bog down in the lower rpm range. Once I get it revving it rips. I'm pretty sure my jetting is a little rich but could that be it. I have no air leaks any where. I've cleaned the carb several times and checked the flaot height. I live in South Fla. at sea level with high humidity and high heat. My bike is a 01 KDX 200 with a Gnarly pipe and fmf silencer, boysen reed valve, and weisco piston. My jetting is main-162, pilot-48, needle- stock R1174K, and my air screw is about 1 1/4 turns out. :bang:
