little jeff
- Aug 20, 2002
- 126
- 0
I had my carb bored out by RB Designs out of Portland Ore. Ron is a really super nice guy. I was told by him that i should be running the DDK needle, or at hotter temps or higher altitudes, the CEJ needle. I tended to get a lot of spooge with the stock NOZH needle, even with the clip in the 2nd from top position. With the DDK needle with the clip on the 2nd from top position, I hardly get any spooge at all. Maybe I should've tried the other needle I had, NOZI. What do you guys think? I know, this question has been probably asked a million times. Ron at RB Designs bored my carb out to 39mm, put in a divider plate on the exit side of the carb, which really helped the low end hit, cleaned up the pilot circuit, and got me pretty close on the jetting. My pilot jet is a 42, my mainjet is a 178, and a DDK needle. I run Dumonde Tech DTP synthetic at 40:1. Any other good possibilities?
Thanks Jeff
Thanks Jeff
