crazy3rdgen
- May 10, 2006
- 84
- 0
On the right side right at the exhaust ,when i rev her up hard it gets all messy.. Is this normal with a 2 stroke??
I get so tired of hearing that myth being tossed around like it's the gospel. Changing oil ratios is almost never the correct fix for a spooge problem. In many cases, less oil will make the spooge worse , because it will make the jetting slightly richer. If you have a problem with excessive spooge, then at least one of your carb circuits is too rich.larosche said:You might be mixing the oil too rich. Try 40:1 for non synthetic. Use 50:1 for synthetic.
That's possible, but it also has a few symptoms of it's own. First, you will lose tranny oil. If the seal is leaking enough oil through it to create a substantial spooge problem, then the tranny oil level will slowly go down as the engine sucks it in. And a badly leaking crank seal will not just leak oil, it will also leak air into the engine. With the combination of the oil and the air coming through the seal, you'll almost certainly notice that your jetting seems to be getting a bit eccentric lately...It could also be a sign that you have a crank seal going bad, sucking in tranny oil
crazy3rdgen said:How should I do this? I had my carb apart checking things out to get more fimiliar with parts and everything. So please give me alittle more detail
Not to step on Rich's toes, but I think it goes "Give a man a fish and he'll eat for a day, teach him how to fish and he'll eat forever."trial_07 said:As Rich said, "you may choose to take fish from someone else or learn how to fish" or something like it anyway.
