different part numbers. The mounting tab near the motor seems about the same spot but the one near the muffler changes - 96 is on the small section of the expansion chamber while the 94's is towards the rear of the big section of expansion chamber pipe. This is going off of computer parts lists and diagrams. You could probably make it work with some cutting and welding but i don't think it would bolt up. Hope this helps
TNutcher
