fatty_k
1,275
What should I do with my chemicals in winter time? Stuff like, half used chain lube cans, half used pre mix, un opened pre mix, etc etc.
I was thinking to just bring them inside, or will thy be fine in below freezing temps?
smb_racing
Master of None
2,085
if you'll notice most of them have a "store between" temperature range on the label, it is best to keep above freezing. Gasoline that's already mixed would be better off being used up rather than stored, dump it in your car to use it up if you don't plan on riding in the winter.
