For some of you who have been reading my posts lately I have a '90 KDX 200 I bought last month and have been trying to tune it in. It was running very different compared to my buddy's '03. Like, I mean, night and day different!! :cool:
After doing a WOT and 1/2 throttle plug chop I noticed a severe lean condition in both instances while the plug was fouling real bad while riding in the low revs around the house. I couldn't figure it out!
A friend said to check for air leaks. I sprayed penetrating fluid around all the seals, rubbers, gaskets with no changes.
Then, I took the mag cover off and it was full of oily gas. About a tablespoon full. Crankseals :eek: finally I found something that could cause my ailments.
So. I ordered both seals and began to tear out the mag and stator to hopefully pull them out from the sides but there are casting 'nubs' at the seals to prevent them from blowing out so now I realize I have to split the cases.
Let me nut shell this for you, I think I'm rambling.
The head was flawless, BUT
both the Kips valves were in four or five pieces each with most of the gear part missing, the Piston is scored and worn virtically and horizontally, there is a huge gouge down the cylinder where the pin must have come out and was riding the wall (I'll come back to this in a minute), the bottom end bearing is shot,the port-job is so extensive that every edge and partitions are paper-thin and razor-sharp and to top it off the Boyseen reeds that were in it are stuck open about 1mm each so they're crap too!
I can't believe it would run! I bought a piece of crap!
Now back to the piston pin. When I took it apart I took both c-clips out myself. So if you think about it, the guy I bought it from realized the bike was not performing anymore and took it apart, found everything chewed, stuck the pin back in the piston, got another c-clip, put 'er back together and sold it to me. The bummer part is that I know him quite well and there was no mention of engine troubles. What an as#h&%e! :debil:
So. I have the bottom end in the shop getting the bottom mains done and the bottom big bearing replaced and will be rebuilding the top end Wednesday to go riding Friday. $1100.00 CAN just to get her to run right. Bummer :whiner:
I am over it mostly and am being optimistic ('cause it's all I have left - optimism) that I will have a smooth running bike that I am starting from scratch with such as a new bike.
Now, for the carb tuning........
Thanks to everyone that shared their ideas to help me along up to this point.
I'll keep you posted about how I like her now. Coming off a KX 125 years ago I was unsure if the KDX power-style would be fun enough.
:thumb:
:thumb:
