crack rock
51
just discovered a cracked reed petal on my rm250 which is equipped with a vforce reed cage. the trouble is my local dealer cant get the replacement reeds they tell me i have to contact moto tassinari directly to get them and im racing this sunday :bang: part of the intake boot has to be cut to install the vforce reed cage and i was wondering if it would be ok to run the stock reeds and reed cage with the cut intake
dales298
Mostly Useless
310
It should be OK. I had to notch the boot on my KX to fit a reed spacer. Just make sure the boot if firmly on the carb neck.
Dale
crack rock
51
what is the point of that little part that you cut off anyway? does anyone know where i can get replacement reed petals for the vforce 2?
