Midhigh
481
I personally wouldn't go any learner than 40:1 & jet accordingly
I'm rebuilding a friends 83 KDX 200 that locked up. He used 50:1 ratio synthetic super M.
My .02
m0rie
469
My .02
Theoretically there shouldn't be any problems with running 50:1. You've just got to insure that your jetting is correct (ie. not too lean) or your seize the engine just as fast as if you were running 32:1. You also need to follow the oil recommendations. Golden Spectro for example, is supposed to be mixed anywhere between 40:1 and 64:1 depending on the type of riding.
-Maurice
CZ511
91
I vote for Golden Spectro (in the gold & black bottle) at 40:1. I have used it in all my bikes since 1980. To this very day, I mix it at 40:1 and use it in my KDX, weedwackers, snowthrower and chainsaw. My Homelite chainsaw is over 20 years old and I always ran Golden Spectro.
KDXFreestyle
645
i use golden spectro and mix 42:1. Always have since it was the easiest thing to get. I have never had any problems or anything. burns good.
john_bilbrey
255
If you're going to go with Bel Ray, spend the extra $$ and go with the H1R. It's a little higher than the MC-1, but it's a better oil. Go with 40:1 and you're set.
John Harris
552
Most old timers will tell you that your KIPS does better and lasts longer between cleanings with all synthetic oil. I use Maxima all synthetic at 40 to 1 and have had excellent results, but other brands work well too. Whatever you decide to use, don't change brands or ratios and work to jet correctly.
canyncarvr
4,005
The lower the ratio (the lower the numbers...20:1 is 'lower' than 40:1), the more power a 2-stroke will make.
Ratios change with application. A woods bike (like the kdx) in the 200cc range (like the kdx) is good @ 40:1.
Ride a couple years with a not-so-hot oil and compare your piston diameter to original. That measurement won't be the same if the oil used is better'n-average.
Is this where I say I put 47,000 miles on my original R5-B pistons using QS-30W?
Henry_Bowman
4
One vote for HP2
I am a little more conservative than most since I really hate wrenching. I use Honda HP2 synthetic at 32:1. *never* fouled a plug with this mix.
m0rie
469
That seems kinda backwards to me. Bikes don't burn oil to make power they burn gas. So having more oil in the mix for a given volume should result in less power. Maybe i'm just reading this wrong though?
-Maurice
CZ511
91
Keep in mind, more oil is not always a better thing. The oil actually holds the heat and the fuel is the coolant. Therefore, there is a very fine balance between oil/gas mixtures. If we mix at 40:1 or 50:1 with decent oil we should all be just fine.
KDXrider045
14
Thanks all!
Thanks all for your opinions...Now I'm really confused :eek:
I've been using Klotz at 32:1 since new. I have to drive a ways to get it however. I've since added to the stable and of course, the other machine has been run on Bel-RAy MC-1 at 50:1. It would be nice to just have one gas can and keep one type of oil in my garage.
moridin
257
I switched to MX2T in a crunch during an unplanned ride. Best oil I have ever used. Stuff is synthetic and totally smoke free.
I think most of the KTM guys are converts to MX2T as well. Best of all - it is half the price of other racing oils and available anywhere. Give it a try - you will really like it.
