hellbertos
- Feb 17, 2004
- 128
- 0
I have been struggling w/ what I assume is an airleak for a while now and was hoping someone (or a few of you) could help me out.
The bike is an '01 YZ125. When I start it up it, the thing just starts reving; maybe like at half throtle. So, I figured, "no big deal, its got an airleak somewhere". I talked to a friend at the bike shop who asked one of the mechs there who said check the reed cage seat + boot, and base gasket. I tore the whole thing down (figured I'd do the top end since I was going to check the base gasket) and found NOTHING... atleast not obvious. Base surfaces were in perfect shape, reed cage surfaces and boot were good. Everything re-torqued to spec. Then I read in Eric Gorr's book about the left side crankcase seal which can deteriorate over time. So, I replaced that, but the bike still exhibits the overly high idle. Also, turning the idle screw on the card has absolutely ZERO effect.
Does anyone here have any advice on where else I can look and/or how to test for it (other than getting it to the shop for a leak down test)? Is there something I am overlooking?? Could this be a problem w/ my carb?? Anyone else gone through anything similar? Trying not to feel desparate... thanx in advance for any info you guys can pass along.
