I have a 1998 CR80 that I just replaced the rear bearings in.
I had thought the bearings were bad so I put new bearings in. It looks like the hub is worn to the point the bearing is able to move a small amount inside the hub. Is there a fix to this? Or is replaceing the hub the only fix? Are there any aftermarket hubs that are cheaper then honda OEM hubs?
