Bob Brooks
- Jan 6, 2001
- 367
- 0
I hate to start another oil thread…but I’m curious as to what you late model YZ250 owners are using in the gearbox. I picked up a used ’02 recently and the shifting seems slightly notchy…not bad, just a little bit sometimes between 1st and 2nd. I’ve hit neutral a few times going between 1st and 2nd when I’m not overly deliberate. I’ve only ridden the bike twice, so it may be my fault so far, I’m just not used to the throw of the Yamaha gear shift lever yet. But in the past, with a lot of my two-strokes, I’ve found many of them to be quite fussy when it comes to gearbox oil. I’ve tried lots of different oils in the gearboxes over the years and never had a problem with clutch slippage or anything like that in any of the oils I’ve tried…but some of them do reveal big differences in how the bikes shift.
I used PJ1 clutch saver in the YZ gearbox so far, only because that’s what I had on my garage shelf, a leftover bottle of it, and I plan to try something else on my next ride and experiment a bit, but I’m curious to hear what some of the rest of you are running in the Yamaha gearboxes and what kind of luck you’re having?
I’ve read a lot about guys using heavy-duty diesel motor oil in gearboxes, and even for four-stroke motor oil, but have never personally tried it.
