Hi, i am have been reading the archives on mods for cr125s, but i am a bit confused now!
Reeds & intake manifold- what year is the best reed cage and intake manifold? what is the best to put in a '00? about the reed spacer, should i keep this or remove it?
Cylinder head- ive read 2000 has the most potential, is this still true?
Piston- what is the best piston to put in? ive read a race vertex piston for a husky cr125 is good?
Carburettor & air boot- I am getting a 38mm carb soon, so what is the best airbox boot to put on?
Cylinder shortening & thinner base gasket- Will increasing the compression take alot of top end power on a stock cylidner head? wont port timing be affected and performance reduced?
Are there any engine parts from different models that i should replace with my stock parts? (manifolds etc)
I cant afford performance reeds, porting or pipes yet, and am about to do a top end rebuild, so i need to no whats best to do while the cylinder is off.
Any help is greatly appreciated!!!!1
