Jeremy, I don't know much about suspension's so I will make this to the point. I took my 00' KX250 apart for a winter cleaning and frame painting, while I have the forks out I pulled out the air screw on top to let them reset. While it was on it's side some oil (I think) came out of the screw hole. Now I don't know how much is still there. Now the springs and set up was fine all year I just need to get the back to where it was. So could you tell me how to drain both forks and replace with oil so they are the same? I did all the tips so told us at DW02 and found that everything was just like you said it needs to be, thank for the pointers. If you could bail me out now that would be great. :whiner: :(
