I'm tring to take off the clutch cover on a '01 YZ 125. I have the 6 bolts out, but it seems like a spring is holding it on. The manual does not show any thing except the bolts holding it.
If I remember right to my '01 YZ 125 clutch days, aside from the regular bolts, you need to remove the clutch actuator arm. There is a little bolt with a washer that goes in to the clutch cover up by it. Remove that, then pull the actuator arm up/out. Hopefully that makes sense.
