Think kawa made the bottom shock bearing better, think again.I greased my linkage from new. I have 8 rides on it took it apart to grease it again and the plastic that sits in between the needle bearings was falling apart.The bearings were fine so I just packed the cage with grease before I installed the bearings,I also put the 03 bearings cage in my 00 kx I will be taking that apart after a few rides to take the broken plastic out.If anyone gets a new bearing for the 03 just break the plastic in between the bearings,IT IS GOING TO BREAK ANYWAY! I was kind of skeptical about the plastic in the bearing design. :| :|
