erider
10
anybody have this happen? the rear shock seal was leaking, now this is a bike with only a few hours on it, it was cold out, below freezing, well took it apart inspected the seal, looked fine, shaft was perfect, put it back together with the same seal, didnt have that size in stock, rode all day with no leaking, if I put in a new seal is it going to leak if it gets cold out? are all the seals made by the same manufacturer, if you get seals from Factory Conn., are they the same as what Race Tech sells? Thanks for any help!!
shaggy829
130
your best bet would be use an mx-tech seal head . it uses a Quad lip seal instead of a single lip seal. the quad lip seal has far superior sealing properties, ..
shaggy
