Roma said:Nicely explained. No other problems w/ RMZ that I can find.
Mophuka said:does anyone know if there are any aftermarket companies that sell different pistons for the bike that might correct this problem?
Nope. Not by itself, unless there were other things going on.06450F said:Can anyone give some insight into valve lash? If the valves clearance became extremely tight or loose could this cause the motorcycle to smoke?
Yes. Worn rings could cause this also.06450F said:Hard starting, loss of power?
Rich Rohrich said:Most four-stroke engines are designed with a piston that carries two compression rings and an oil ring package (two thin rings seperated by a spacer) . The second compression ring on these pistons really serves more as an oil scraper than a compression ring. This second ring scrapes oil off the cylinder wall which helps prevent it from slipping by the top compression ring and burning in the combustion chamber. It's a common trend for ultra high speed engines to use only a single compression ring and the oil ring package in an effort to reduce friction losses and to allow the piston to be as short and light as possible to permit the high speeds these engines can safely run at. The RMZ engine is designed with this current engineering thinking and only uses a single compression ring. When the engine is cold it is difficult for the single compression ring to stop all the oil. This situation is at it's worst when the engine is new, but it will always do it to some degree even when the engine is broken in. Single compression ring four-strokes always tend to use more oil then their dual ring competitors. Using a little bit of oil in exchange for performance is a good trade off in the long run for most of us.
Once the single compression ring starts to wear they start to leak like a sieve, and the only fix is to replace the rings and maybe the piston.
All the blather on the internet about special break-in procedures fixing this, is just wishfull thinking. The OEMs can change the ring face coating and help it last a bit longer, and some may work better than others but as long as there is only one compression ring you are going to use some oil.
Mophuka said:well I redid the topend. put a new set of rings in and checked the cylender for wear then checked the valves. buttened it all back together but still smokes when I start it up.
06450F said:As Mophuka stated. He got the top end all rebuilt but his bike does still smoke at start up and warm up. Now granted the machine performs great.....but still my question and im sure Mophuka (pernounced...Mo ****a.....as in Mutha Pucker,ehehe) is that his machine has been rebuilt up top.....shouldn't this have solved the smoking?
I (we) understand a little bit of smoking while cold is normal. All of my street bikes do it, and so does my KX450F. But it only smokes a tad and only when rev'd a decent amount while very cold. His RMZ450 is still smoking enough while cold to leave that little lingering wonder in the back of his (and my) mind.
Mophuka said:didn't have the cylinder rehoned. looked in the cylinder for wear marks but neglected to have it rehoned. guess that could explain the smoking problem. this is the first time I have done this to a 4 stroke bike and I still have some stuff to learn. Used regular oil. staying away from the synthetic stuff for a now.
could not having the cylinder rehoned cause any damage in the future. I planned on going through and rechecking the valves in the next 15 hours. being that I will have the engine apart I could easily redo the rings and have it rehoned. or should I get this done ASAP.....
thanks for the help...
