05 YZ 250, bent shift fork replacement(now with pictures)?
Hi, I've got an 05 yz that had tranny troubles. Found out two shift forks were worn so I'm replacing them as a set, but in the manual it says if you replace a shift fork to replace the two gears each adjacent to the shift fork. What do they mean by this? Do I need to replace all gears contacting a shift fork and all mating gears associated with them?
Also, is there a way to make sure I didn't bend one of my shift shafts(3rd gear snapped a tooth off) or does everyone just eyeball them with a straightedge?
Thanks for any answers, I'm really lost on what I need to replace when replacing a shift fork, any help is really appreciated.
Jeff
Jeff
