dpgalvin said:Hi, I am just wondering if anybody else has experienced gearbox failure on the 06 yz 250.
First time I hear such a thing on a 2006 yz250. It sounds like some teeth are broken off the gears. Did you tri other gears to see if it is the same.dpgalvin said:sounded like the sprokets slipping in second and third gear.
Will post what happened later
dpgalvin said:No, I use Castrol 10w40 synthetic and change after every ride.
mxduner said:whats so bad about atf? is'nt that what they use in auto trannys that also uso wet type clutch discs and gear boxes?????
All I will say is your bike tranny is not an automatic car transmission in design or function.
its not a car engine either and a bike tranny is much more similar to an auto trans than a car engine which motor oil is designed for
