NO HAND
- Jun 21, 2000
- 1,198
- 0
Current shock shims:
12mm Nut
25mm heavy washer
25.3 shims
26.3
27.3
28.3
29.3
30.3
32.3
34.3
36.3
38.3
40.3
32.1
40.2
40.3(x5)
22.1
40.2(x3)
Base valve
(compression stack)
44.25(6)
44.20
38.15
30.15
42.25
40.25
38.25
36.25
34.25
32.25
30.25
28.25
26.25
24.25
22.3
21.3
plate
Fork:
base valve
nut
washer and spring
30.5 *0.4
piston
30*0.1 (15)
29.1 (2)
28.1
27.1
26.1
25.1
24.1
23.1
22.1
21.1
20.15
Bleed
30.5*2mm plate
16*0.3
10*0.2
12*0.1
14.1
15.1
16.1 (2)
midvalve
nut
12.5*2.5 washer
12*0.2 (6)
10*0.2
11*0.1
12.1
14.1
16.1
13.1
19.1
20.1 (2)
piston
20*0.1 (4)
17.1 (3)
8*1.88 post spacer
9.5*0.2 (2)
11*0.3
float = .15
float spring
12mm Nut
25mm heavy washer
25.3 shims
26.3
27.3
28.3
29.3
30.3
32.3
34.3
36.3
38.3
40.3
32.1
40.2
40.3(x5)
22.1
40.2(x3)
Base valve
(compression stack)
44.25(6)
44.20
38.15
30.15
42.25
40.25
38.25
36.25
34.25
32.25
30.25
28.25
26.25
24.25
22.3
21.3
plate
Fork:
base valve
nut
washer and spring
30.5 *0.4
piston
30*0.1 (15)
29.1 (2)
28.1
27.1
26.1
25.1
24.1
23.1
22.1
21.1
20.15
Bleed
30.5*2mm plate
16*0.3
10*0.2
12*0.1
14.1
15.1
16.1 (2)
midvalve
nut
12.5*2.5 washer
12*0.2 (6)
10*0.2
11*0.1
12.1
14.1
16.1
13.1
19.1
20.1 (2)
piston
20*0.1 (4)
17.1 (3)
8*1.88 post spacer
9.5*0.2 (2)
11*0.3
float = .15
float spring
