Anyone put a 13t front sprocket on a 300MXC? This thing doesn't bridge the gaps between 1st and 2nd and 2nd and 3rd as well as I would have expected. Gearing seems like it would be an easy fix but the gaps I have felt would need at least 2 teeth on the rear and I don't want to go that big. This problem is only noticeable in the hills, but I live in Nor Cal... lots O hills. The gears are taller than I am used to so I am finding myself in 1st and second a lot more than my yz. While shifting up hill from 1st or 2nd to the next gear, it can be difficult to keep the revs up. I'm also thinking jetting could be a slight factor. I dropped the main from a 178 to a 175 and it really cleaned up the top, but the transition from the lower throttle postions seems a bit fat. I haven't had time to mess with the pilot or needle.... no need to reply to the jetting question if you don't live in nor cal or similar climate. 1000-3000 feet 65 degrees (this time of year)
JL
JL
