My cousin has a 1975 RM 125 with a fresh rebuild. The machine has no power whatsoever until you reach about 14k RPM's. Is this normal. I have to believe that something isn't adjusted right. I mean it's totally gutless until you get to the very narrow power band. To the point that you must ride out the clutch just to get moving. It will stall if you hold it at about half throttle and dump the clutch from a stand still. The carb seems to be jetted really rich, but only appears to have a main jet, and no other adjustment other than the air screw and idle screw. Am I missing something. This machine is a little too low tech for me!
