P prumz Member Dec 11, 2004 12 0 Oct 9, 2012 #1 Would anyone out there know the matching Mikuni needle part number to the original supplied in the C1. Original part number is 6FL52. My local Mikuni dealer is being less than helpful with this. Mine is worn out so would really like to replace it. Any help greatly appreciated. Thanks
P prumz Member Dec 11, 2004 12 0 Oct 16, 2012 Thread starter #2 OK, no responses to that question so I will try this way. Any recommendations for jetting on said C1. Standard engine and exhaust. Bike generally used between sea level and 2000 feet.
B Bark3rd Member Jan 5, 2009 45 0 Oct 30, 2012 #3 That's not a Kawasaki part #. You need to look at the parts fiche http://www.kawasakipartshouse.com/h...1986)/CARBURETOR/KDX200-C1-1986/C11C1181E1611 there are more than one needle jets listed, but it appears the stock one is 16017-1307 (R2) search- "kawasaki 16017-1307" R2 (search without the R2 in the text) or change the search as per the different part #s on the fiche if you want an optional needle size easy to find.
