Guys
after stripping down the front caliper this weekend I have discovered the previous owner
had stripped both the threads on the backing plate on the front caliper and just glued the bolts
in!!!! :-0
I am trying to find a new plate part number 43044-1034 (i think) but they are £77 ($138) just for
the plate!!!
My question is...
Is the caliper the same as any of the other kawasaki models ie AR125 etc
Can anyone suggest a solution and the auctions sites dont have any on and I can't afford £80 for a bloody plate
There is 1 going on e-way that delivers world wide, it's the whole thing cable and master cylinder from a 1989 KDx200 :cool: You these for your search KDX 200 FRONT and click Search title and description
Guys in case anyone else has this problem I took the back plate to my local presision engineering company and they drilled out the hole to 10mm and inserted a threaded 8mm sleeve. this worked perfectly and cost me £15 or $25
