mxman2000
60
bryanv said:
Hi Was out riding today and now 3rd gear goes into neutral. All other gears work fine. No noises from tranny. Any suggestions
Probably strpped your third gear, your not in neutral, Its just not engaging cause the gear is worn/destroyed. Looks like you will need a bottom end rebuild :(
1998RM250
426
Can you skip through 3rd and into 4th at least? Sorry to hear that man, it's always something right!?!
bryanv
the bike will go into 4th. Maybe a fork is bent. I will take it apart with a buddy of mine. Hopefully nothing else is wrong, but once you start where does it end.
2strokerfun
1,500
You'll have to check it out. Obviously, start with the shifting linkage under the right side of the engine cover. Sometimes, it's a simple fix. If it's not there, probably have to split the cases.
