1999 rm125 help
I just did I top end rebuild on my bike I had 60 psi before the rebuild and 180 after I couldn’t get the bike to start for a few days and finally I got it started with a little starting fluid and I saw it was blowing out radiator fluid out of the discharge/overflow of my radiator but I kept it running for about a minute or two then I released I was spraying radiator fluid out of the gap between the cylinder head and the cylinder and I must not have put the seals in correctly was wondering if I just put new seals in it will be fine or if I may have damaged anything by running it like that
