Yes you can adjust the preload with it all together,I use a socket extension and a hammer.I have a 00 kx250,I weigh 185 .First off change that oil get a manual the kayaba's are pretty simple.The standard oil height is 90mm I am running a little higher 80mm to fight bottoming.Here is my setting .43 springs, 6 on the compression and I am flirting around with 13- 15 on the rebound If I set the compression on 8 they are plush for me,but It does not like over jumping or g-outs.That is why I am running in at six With 6 the small choppy stuff it is harsher,but I take it out on the rebound.I still don't like how it corners though I am very aggressive in the corners,but the front wants to knife in on me.I tried pulling the tubes down from 5mm to flush,but the front felt dead.Change that oil and fit yourself with some springs,then start gone crazy on the clickers. :thumb:
