Originally posted by Rodzilla
I'm taking a different tack from Tex on the filter screen though, I'm of the mind to leave it in as is Scott Summers, he says removing it is not needed and that it changes the airflow in a negative way. just my opinion.
Rod
Originally posted by HammerXR
You guys are missing my point. I'm not saying that you should assume "all systems are GO" -right from the dealer. Go ahead and make sure that the bike is ready to ride by checking it over, and doing things like adjusting the bars, levers, and sag, etc. Also, of course, make sure the fluids are full, the bolts are tight, tire pressures are right, etc. Any doofus should know to do this.
I'll have do drill the stops all the way thru or go in and thread them properly instead of just cranking in a self tapping screw.
