SQUIRLEYMOFO
310
No doubt that a 2002 pipe will fit on a 2003 CR250.....but what is the difference? I've found a new old stock Pro Circuit Platnium pipe for a 2002 at really good price. The part # is different.....but I don't see any differences.
rosscopeeko
156
I'm not positive, but i thought i read somewhere that the flange was a little longer where it joins the cylinder. You might want to contact pro-circuit and ask them.
jib
67
The 02' pipe will bolt right up to an 03' with no problems. The frame and engines are identical. Some of the suspension parts, ignition mapping, and cylinder porting are different.
tony91
493
Rossco is correct. 2002 pipes will not fit 03-04 Cr250's.
