Originally posted by MikeS
If your rider is just starting out or not keeping it WOT, try a B8es plug. That may help the low speed fouling.
I agree - won't hurt to try a BR8ES plug and see if that helps. When I rode 80's (as a beginner rider) I needed to drop down to the 8 heat range to prevent fouling. Although more experienced 80 riders mostly run 9 and 10 heat range plugs (but these are the guys that never let off the throttle, too).
If that doesn't help - sounds like you may need to lean out the pilot, main, or clip position. How do the plugs look after just one ride? And how does the bike run through the different throttle settings (0-1/4, 1/4-3/4, 3/4-full, etc...)?
