I have picked up a heavily used YZ250 for a good price, knowing that I must do much service to it.
I bought the 14mm hex key and the long fork tube tool.
-I first pulled the forks and drained the oil. (Very black & stinky)
-Then inserted the tool and the 14mm key and began disassembly. The innards came out but the valve on the bottom would only spin.
-The second fork came apart completely different, ei. the internals came out but the inner tube stayed in the fork. I was unable to get the inner tube out and the valve on the bottom would only spin, same as the first fork.
I was running out of time so I reassembled and topped up the oil. Now I don't seem to have any change in the comp or rebound when adjusting the valving.
Another note: The top adjuster on one fork gives me 20 clicks (which I believe is normal) and the other gives me 40...
I do have the manual and look forward to digging back in when I have some better direction.
Any help would be greatly appreciated.
Doug
Doug
