Duc-Monster
- Jul 2, 2002
- 17
- 0
I run a FMF Fatty pipe with the shorty silencer, as well as the Boysen reed valve. If you want a smoother power delivery with more down low-end (4-stroke like) this is the way to go.
Originally posted by Coop37
What gas oil ratio are you running?
regular super pump gas at 32:1 with motul 600
Also, set the float level a little leaner, like 7.0 mm
thats interesting, i assume this is easily done but can it make the settings go horribly wrong or just move them a bit?
You may have to richen the mid a bit when you do the float height?
I'm still slightly rich in the mid, but the top clip position seems to be too lean. I'm going to try the half step leaner needle.
We use cookies and similar technologies for the following purposes:
Do you accept cookies and these technologies?
