Originally posted by motometal
But, the 2001 is a great bike also and it will be a sad day when it's sold.
Motor: Softer on the bottom than the 2001, very quick revving in the middle and ok but not great over rev (jetting?). Not a beginner's bike, keeps you awake for sure! Lots of wheelies!
Also, at low rpms there is a knocking noise, probably from the piston, louder than engine noise on my 2001. I'm not used to this, anyone else notice this on their bikes? It goes away as the motor is revved a bit higher.
Originally posted by SpectraSVT
I'm a beginner and it wasn't enough bike for me. I would say its a PERFECT beginner bike. Motor doesn't have any hit at all so its easy to keep the rear wheel from breaking loose.
*mine doesn't have enough power to wheelie over a log in 1st gear if the motor is lugging,
*I was thinking about getting the MX Bonz kit...Or how about taking out the foam gasket and just using silicone?
*Faded, 350 or 360 main sounds really lean, but then you are at a higher elevation.
but seeing a plug that white on the tip would scare me a bit...Was that a new plug just run briefly at WOT?
Originally posted by Buzz Bomb
For the airbox problem, everyone always says silicone is bad, but has anyone here actually tested and had gas break down their airbox junction?
Originally posted by James
Something is wrong with your bike then. We ran across a guy that was saying the same thing a few weeks back. Turned out that he had his powervalve apart and put it back together wrong.
I do know how to jet mine and turn the throttle past 1/8th...nothing freakish about that.
Any other comments on the low rpm piston rattle? This probably doesn't hurt anything, but is a bit annoying.
Originally posted by Superchief
I believe the RC valve opens proportionately to the throttle opening.
We use cookies and similar technologies for the following purposes:
Do you accept cookies and these technologies?
