I take excellent care of my bikes and I tore up a stock chain up in less than a month. They are junk. I am still running stock sprockets and an x-chain and now the drive chain is maintenance free. 3yrs on stock sprocket and a cheap x-ring from parts unlimited. I am a believer of junk hadlebars and junk chains. I am also a believer in the lowest bidder wins cheaper the better in the manufacturing business.Jaybird said:My bet is the adjustment procedure needs looked at.
Make certain you have a straight like from the CS thru the swingarm to the rear sprocket. This is the tightest point that the set-up can obtain. 1/2"-3/4" slack at that point, as mentioned before.
Do it this way one time, and check to see how much room there is once the bike is back together and on the ground. This way you can check your chain tension any time you are out riding.
The sag of your suspension has nothing to do with your chain tension.
People are far to quick to blame the stock chains. They last far longer than folks say they do. It's just that many don't adjust or maintain properly.
Titanium sprockets and 200$ ring chains are nothing but a bandaid for the problem.
A man who properly maintains the equipment will have as good of luck with aluminum sprockets and a 30$ chain.
Is this statement in keeping with "excellent care"? Because there are no maintenance free chain drives in existance. Only the mis-perceptions of such.fatherturtle said:...now the drive chain is maintenance free.
Jaybird, what lube do you recommend? I use maxima witch is pretty gooe. You may be right I would just usually spray the lube until it is dripping. Maybe 30 seconds to get this effect. i never spent much time cleaning the chain. Maybe that is why the stock chain doesn't last long. I do have an x-ring that is vitually maintnance free. I use maxima chain wax now and two years no adjustments needed. I know there been threads on pro's and cons on both, but man they are like ten pages.Jaybird said:Some lubes are on the top shelf of many dealers and shops, and one would assume they would have to be great products. But the truth is that many of the conventional lubes, that are the best sellers for bikes, are so thick and gooey that they may not even pentrate to the friction areas before they set up. Leaving you with confidence that your chain is lubed, when it only has thick goo around the outer surfaces of the chain.
And what sort of time does it take to lube a chain? I can slosh on chain lube in about 30 seconds if I'm in a hurry.
Do you not have to refuel after at least the halfway mark of an enduro? (I know squat about enduro riding so maybe not)
Wouldn't that be sufficient opportunity to ensure that your chain has been lubed...that is if you are using a lube that actually works. With some lubes, the last thing you would want to do is apply it after the chain is dirty. Then you have nothing but a grinding paste to help eat things up.
On worrying about your chain...I have to agree that worrying about your chain should be the least of your worries during a ride. But, there are far more problems that can occur during a ride or a race with a ring chain than with a standard. With a standard chain you never have to worry about the rings being torn by something on the trail, and you never have to worry about if the rings have been sufficiently lubricated so they do their job in the future.
But, I will grant you that if luck prevails, a ring chain will serve you fine. -And should be used if there is muck and slop involved.
We use cookies and similar technologies for the following purposes:
Do you accept cookies and these technologies?
