2003 yz 125 carb problems
alex_99
I own a 2003 yz 125 and last week i decided to take my carb off my bike so i could clean it.When i put it back in the bike,as soon as my bike started the engine revved like crazy without even giving it gas anyone can help me ouot with this???
Jun 28, 2006
94
Throttle cable adjustment (preloaded) should have some free play in the throttle. Carb slide sticking?
2strokerfun
1,500
You either have the throttle cable in a bind, or you have an air leak at your intake. Check the cable and make sure it is moving freely and your throttle valve is going up and down in your carburetor. Then check and make sure your carburetor is straight into your intake manifold and it is tightened up properly with no air leaks.
Cookies are required to use this site. You must accept them to continue using the site. Learn more…
