2007 Honda CRF150R Expert / Specs
Okiewan
Admin
2,238
Texas
ENGINE
Engine Type 149cc liquid-cooled single-cylinder four stroke
Bore and Stroke 66mm x 43.7mm
Compression Ratio 11.7:1
Valve Train SOHC; four-valve
Carburetion Keihin 32mm flat slide with throttle position sensor (TPS)
Ignition Solid-state CD with electronic advance
DRIVE TRAIN
Transmission Close-ratio five speed
Final Drive #420 chain; 15T/56T
CHASSIS / SUSPENSION / BRAKES
Front Suspension 37mm fully adjustable leading-axle inverted Showa cartridge fork; 10.8 inches travel
Rear Suspension Pro-Link fully adjustable Showa single shock; 11.5 inches travel
Front Brake Single 220mm disc
Rear Brake Single 190mm disc
Front Tire 70/100-19
Rear Tire 90/100-16
DIMENSIONS
Rake 27°48'
Trail 96mm (3.85 inches)
Wheelbase 50.6 inches
Seat Height 34.1 inches
Ground Clearance 13.2 inches
Dry Weight 169.7 pounds
Fuel Capacity 1.14 gallons
OTHER
Available Colors Red
Model ID CRF150RB
Cookies are required to use this site. You must accept them to continue using the site. Learn more…
