Okiewan
Admin
2,237
Texas
ENGINE
Engine Type 149cc liquid-cooled single-cylinder four stroke
Bore and Stroke 66mm x 43.7mm
Compression Ratio 11.7:1
Carburetion Keihin 32mm flat slide with throttle position sensor (TPS)
Ignition Solid-state CD with electronic advance
DRIVE TRAIN
Transmission Close-ratio five speed
Final Drive #420 chain; 15T/50T
CHASSIS / SUSPENSION / BRAKES
Front Suspension 37mm fully adjustable leading-axle inverted Showa cartridge fork; 10.8 inches travel
Rear Suspension Pro-Link fully adjustable Showa single shock; 10.8 inches travel
Front Brake Single 220mm disc
Rear Brake Single 190mm disc
Front Tire 70/100-17
Rear Tire 90/100-14
DIMENSIONS
Rake 27°02'
Trail 78mm (3.07 inches)
Wheelbase 49.6 inches
Seat Height 32.8 inches
Ground Clearance 11.9 inches
Dry Weight 165.3 pounds
Fuel Capacity 1.14 gallons
OTHER
Available Colors Red
Model ID CRF150R
