Hey,
Im 13 but I'm only 4' 7so I need to get a smallish dirt bike.... :( :pissed: which dirt bike is the best?
2006 Honda CRF 80 Specs:
Engine: 80cc air-cooled single-cylinder four-stroke
Bore and Stroke: 47.5mm x 45mm
Compression Ratio: 9.7:1
Valve Train: SOHC; two-valve
Carburetion: Single 20mm piston-valve
Transmission: Five-speed
Final Drive: #420 chain; 14T/46T
Front Suspension: 27mm leading-axle Showa fork; 140mm (5.5 inches) travel
Rear Suspension: Pro-Link Showa single shock; 109mm (4.3 inches) travel
Front Brakes: Drum
Rear Brake: Drum
Front Tire: 2.50-16
Rear Tire: 3.60-14
Wheelbase: 1209mm (47.6 inches)
Seat Height: 734mm (28.9 inches)
Dry Weight: 70kg (154 pounds)
Fuel Capacity: 5.7 litres (1.2 gal.)
2006 Kawasaki KLX 110 Specs:
Engine: Four-stroke, SOHC, two-valve single
Displacement: 111cc
Bore x stroke: 53.0 x 50.6mm
Compression ratio: 9.5:1
Cooling: Air
Carburetion: Keihin PB18
Ignition: CDI
Transmission: Three-speed with automatic clutch
Final drive: Chain
Frame: Backbone frame, high-tensile steel
Rake / trail: 25.5 degrees / 2.1 in.
Front suspension / wheel travel: 30mm hydraulic telescopic fork / 4.3 in.
Rear suspension / wheel travel: Swingarm with single hydraulic shock / 4.2 in.
Front tire: 2.50x14
Rear tire: 3.00x12
Front brake / rear brake: Mechanical Drum / Mechanical drum
Overall length: 61.2 in.
Overall width: 26.0 in.
Overall height: 37.6
Ground clearance: 7.5 in.
Seat height: 25.6 in.
Dry weight: 141.1 lbs.
Wheelbase: 41.9 in.
Fuel capacity: 1.0 gal.
2006 Suzuki DRZ 110 Specs:
Engine: 111cc, 4-stroke, single-cylinder, SOHC 2-valve, air-cooled
Bore Stroke: 53.0 x 50.6mm
Compression Ratio: 9.5:1
Fuel System: KeihinTM PB18
Lubrication: Wet sump
Ignition: CD
Transmission: 3-speed, auto clutch
Final Drive: 420 Chain
Overall Length: 1555mm (61.2 in.)
Overall Width: 660 (26.0 in.)
Overall Height: Ov955mm (37.6 in.)
Seat Height: 650mm (25.6 in.)
Ground Clearance: 190mm (7.5 in.)
Wheelbase: 1065mm (41.9 in.)
Dry Weight: 64 kg (141.1 lbs.)
Suspension Front: Telescopic, oil-damped
Suspension Rear: Link-type, oil-damped
Brakes Front: Single Drum
Brakes Rear: Single Drum
Tires Front: 2.50-14
Tires Rear: 3.00-12
Fuel Tank Capacity: 3.8 liter (1.0 gal.)
Let me know,
Belle
Front Brakes: Drum
Rear Brake: Drum
Front Tire: 2.50-16
Rear Tire: 3.60-14
Displacement: 111cc
Cooling: Air
Ignition: CDI
Final drive: Chain
Front tire: 2.50x14
Rear tire: 3.00x12
Wheelbase: 41.9 in.
Ignition: CD
Tires Rear: 3.00-12
Let me know,
Belle
