KelvinKDX
- Aug 25, 2000
- 1,622
- 0
I was doing a compression check today (as my bike is running poorly) and was suprised to see that the gauge was not registering any psi.
kick, kick, kick = 0 :(
Bike is 2-stroke. I have the pipe, carb and reed block off of the engine. Should this make a difference? I checked out the gauge on another bike and the gauge itself seems to work fine. I did have the o-ring of the compression gauge seated down to the head. I did not warm up the engine as i had critical items to make the engine run off of the bike (like the carb).
Is it ok to do the check with the reed block off? I expected to at least get some reading.
Bike symptoms: very hard to start, no power, will not run at low rpm (dies).
fyi: I've already read through many threads on compression checks via SEARCH but did not see an answer to my question.
Rings & gaskets are on order.
