Guys, I'm working with an older (2000) kx125 that I'm trying to work the bugs out of. I have been searching the archives here and have found that there were updates to the stock jetting to improve bottom-end from the factory. Referencing this thread *Link* --> ( 2000 Kx125 jetting ) and this thread as well as the original letter with the updated jetting specs recommend that I run a #40 pilot jet.
I currently am running the stock #45 and it seems to run best at 1_1/2 turns out to 2 turns out. I attempted to switch out the #45 for the supplied #40 the other day, but had to crank in my air screw to only 3/4 of a turn to get rid of the bog I would get when whacking the throttle at idle. Now from all the info I've gained in the past 3/4 of a turn dictates that I should be staying with the stock #45. Am I correct in thinking this? I was attempting to get rid of the spooge I'm getting from the tail pipe right now, but do not want to run too lean of a pilot to accomplish it. I know this is now an older bike, but can any offer any assistance?
